USB-port replacement due to bend pins.
Hello there!
I got a question regarding the USB-port connector. Do you guys know what sort Apple is using for their products?
Can you replace it with a regular USB Type A connector 4P?
Bu iyi bir soru mu?
Hello there!
Bu iyi bir soru mu?
As this port is built into the logic board, you might want to try to straighten then or have a tech do it.
Bu yanıt yardımcı oldu mu?
I have tried that but its too far in, I can't seem to get a hold on the bend pin. Its pressed against the back of the connector. And if I get a hold on it, don't you think it will snap since its been bent once already?
Picture of it: http://img199.imageshack.us/img199/9486/...
@Frederik, looking at the image, I would think right now you do not have much to lose. I would use a few straight pins and tweezers and give it a try.
Looking at your picture, I would use a dental pick (the shepherds crook type), see these: Probe and Pick Set
I found a old tweezer but it was too big so I had to modify it, after that I tried grabing it and after awhile I got it! I straighted it out and pulled it to place. It seems to work!
http://img547.imageshack.us/img547/4076/...
The tweezer didn't leave beautiful marks but who cares, it works! I haven't had 2 usb-ports working for over a year!
Thanks for the help :)
Great job:-) Now all you have left is to accept mayer's answer as the one that helped you the most :-) that way anybody having the same issues will know what might work. Best of luck to you
Tried fixing mine with a paper-clip. I thought it got it into place, but after testing it twice, gingerly with a USB cord it broke :(
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,397
