Ana içeriğe geç
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Soru Tümünü görüntüle
Missing capacitor near HDD cable connection on logic board
I have recently rebuilt a Macbook Pro A1286. When I got to the point of installing a HDD, I noticed a missing capacitor, very close to the HDD connector on the logic board. I can include a picture, and if I can determine the value of it, I believe I am capable of resoldering it on. Any help pointing me in the right direction is very much appreciated!
Bu iyi bir soru mu?
Puan 1
6 Yorum
There are 22 machines in the A1286 line. Please give us the last thee numbers of your serial number so we can identify which one you have. Also posting a photo would really help.
tarafından
I'm not sure how to attach an image, though I have one. I do not have the serial number as I am at work, but it is an early 2009 2.4Gghz 15 incher.
tarafından
Serial number is- W891602XC6DZA
tarafından
I'm having a bit of trouble finding a DLP11S rated at 90 Ohms. Is Digikey the place to hunt? And by the way, you are THE MAN!! I had little hope of finding this particular part. ifixit RULES!!
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Andrew, double check your serial number. anyhow, what you are missing is not a capacitor but a Common Mode Choke Coil 90-OHM-100M DLP11S. Check here for the datasheet. It is part of the SATA connectors and SATA HDD circuit. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Andrew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 319
