check engine lit on and gas cap alert
the check engine light came on and later followed by gascap light. have changed gascap but cant seem to be able to reset, since i dont have a manual since my 07 caravan was bought used.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
cdelasancha18, it should normally reset itself if you have driven it a few times after you replaced the gas cap. It is possibly that you have other issues. Take it to a place like Autozone, or anyone else, that offers a free quick scan and see what codes you get. It is possible that you have trouble with your ESIM valve, or even your oxygen sensor. You can, of course, try a reset by removing the negative (-) cable from your battery and leaving it off for a while. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 7,997
