Ana içeriğe geç
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 Soru Tümünü görüntüle
Soru Kapandı
s2 not charging battery to 100%
S2 battery holder jack inside battery chamber.. Showing open circuit voltage..4.16only..no over heating any where...i hve already replaced usb flex ..bt same problem ...
On charging ..while m running heavy application ..battery goes down
Max battery charge voltage(closed circuit)4.012
Battery charger is ok... Nd delivering 5 volt on mother board
S2 model is i9100G
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I do believe that if you push these these phones hard enough, you can actually drain the battery even if you have it plugged in and "charging." I know one of my buddies did it downloading and gaming at the same one before. 4.16volts is kinda high for a 3.7 volt battery though. I've seen mine max at roughly 4.02 volts, but that's on a Galaxy S2 Skyrocket.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,720
