Ana içeriğe geç
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Soru Tümünü görüntüle
Soru Kapandı
iPad 2 Wifi picks up, but fades quickly.
Hello,
I have an iPad 2 (Wifi) 32 GB's and I somehow dropped it and the wifi doesn't really work as it should. It picks up a signal sometimes and then goes away, I'll be right infront of the router, but sometimes doesn't pick the signal up. I'm not really sure if I need to fix the wifi antenna or something else.
And if I need to fix the antenna, this tutorial will work fine? iPad 2 Wi-Fi EMC 2415 Bluetooth/Wi-Fi Antenna Replacement
Any help is greatful!
Bu iyi bir soru mu?
Puan 0
1 Yorum
Bump? Anyone have an idea?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The iPad 2 wifi setup is pretty simple. It is just one flex cable that runs near the home key at the bottom of the iPad.
That being said your issue sounds like the small connector that attaches for wi-fi signal has probably come loose. (you can see it closely @ step 43)
Unfortunately it seems you are going to have to open your iPad. The guide you have chosen is the exact one that you need to be able to fix this issue.
I highly recommend caution, go slow, pay close attention to the notes in each step. There are flex cables that are easily broken during the removal of the front glass.
What I would do is open it up, get yourself to step 43, and check to see if that connection is secure. Most likely it has come out or isn't seated properly after your unfortunate drop.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
That's what I was thinking. I'm just kind of worried about opening the iPad myself.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 434
