Ana içeriğe geç
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Soru Tümünü görüntüle
Laptop won't power up
Hello, I replaced a lcd screen in a early 2011 MBP and when I try to turn it on, nothing happens. I have tried all the normal things such as disconnecting the battery, making sure my cords are properly seated, etc, the battery had most of a full charge, when I press the battery status button, it lights up to show me how much battery there is and when I plug in the power cord, the light on it comes on as well. I have also tried to reset the PRAM/NVRAM and I had no luck. I also followed the instructions to reset the SMC, when I did that, the light on the magsafe connector did change, almost acknowldeged that something happened but that still didn't fix the problem, just nothing at all happens when I press the power button, is there anything at else I can try?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello,
you have fully recovered the keyboard cable?? because it is not always easy to insert to the end ...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I agree with Eldoctor62. If you get no activity when pushing the power button then check the top case ribbon cable connection the logic board.
tarafından
Yorum Ekle
Yanıtını ekle
bigjkcfan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 349
