Ana içeriğe geç
Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
2233 Soru Tümünü görüntüle
Soru Kapandı
I've had to deal with recessed screws while disassembling a laptop
I am going to purchase either the Home tech Toolkit or Pro Tech Toolkit (depending on finances) soon.
I also need a small assortment of philips-head screwdrivers that can hold a screw upright while putting it into a recessed place -- way too deep to hold on with my fingers. Enough room for the screw to fall over, but not enough room to put tweezers in with the screwdriver.
It doesn't look like either toolkit has these, and I can't imagine that you don't sell them. Please point me to the right product.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Maggie, thanks for your question! The bit kits included in the [bağlı ürün eksik veya kapalı: IF145-047] and [bağlı ürün eksik veya kapalı: IF145-072] each contain a 60 mm driver extension that may allow you to reach into recessed screw holes.
However, in some cases this isn't thin enough—for those situations you'll need a fixed driver. We sell these for every Phillips size, that can be magnetized to hold onto screws. For laptops I'd recommend a Phillips #1 and Phillips #0. For really small recessed screws, you'll need a Phillips #00.
Phillips #0 Screwdriver Görseli
Ürün
$5.49
Phillips #00 Screwdriver Görseli
Ürün
$5.49
Phillips #1 Screwdriver Görseli
Ürün
$5.49
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 1,230
