Ana içeriğe geç
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
23 Soru Tümünü görüntüle
Soru Kapandı
My computer displays "Failed to create E:\sdv.flg error" what to do?
I tried to reboot my computer and when I used the first install disk from HP, after about 4% of it being complete a message pops up saying "Failed to create E:\sdv.flg error". I was wondering what the issue is and how to fix it. The computer is less than a year old and tech support was no help from HP. I was on hold while they tried to figure out what was happening for 45mins and came up with nothing
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It sounds like you are trying to restore the operating system from the restore cd. Is this correct?
Possible cause of failure durring the OS restore could be a scratched or dirty cd, bad RAM or bad hard drive.
Double check the CD that it is clean and has no scratches.
To test for bad RAM and hard drive I believe there is a test inside the BIOS, which you can access by pressing the proper key right after turning on the computer.
If there isn't a tool to test RAM and hard drive in the BIOS, if you have access to another computer, you can find download and burn the Ultimate Boot CD, which has a RAM (Memory) test, and hard drive test.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 482
