First generation of Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
86 Soru Tümünü görüntüle
So if/when I break the clips...
I have an iPad 3G that needs a charging port replaced. I ordered the charging port cable, and sat down to watch some repair videos.
Everything I have seen and read indicates that I WILL break MOST of the Digitizer clips when opening it. I don't have a replacement screen or extra clips.
Is there a way to open it, replace the charging port and seal it back if the clips are broken? Or do I just need to order clips (how do they reinstall?) or even a new digitizer?
I am missing the glue already.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
these are a bit tough to do if you've never done one before.
What I do is I usually take these apart starting from the right side.
I break 2 clips - one at the top right corner and the other one and the bottom right corner. Sometimes you will break the clips at the bottom or top but not the side ones.
Once you have a little of a gap, unplug the 3g antenna and you can grab the screen assembly basically hit the metal piece in a place that won't damage it. You want to hit it in the long part of the case - so the side where you are sticking your hand in to hold the screen. You have to hit it while holding the screen assembly. Good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
DocMartigan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 166
