Unable to remove existing hard drive
Hi everyone,
I've followed instructions from this site and a couple of YouTube videos.
The existing 5400rpm hard drive seems to seat differently that on the instructions and videos. It is seated deep down and will not come off. I can't even reach it with my fingers to try and lift it up.
Is there something I'm not doing correctly or has Apple changed the design? If so, do I need to remove the logic board perhaps to make more room?
Thank you!
Bu iyi bir soru mu?
7 Yorum
Can you supply us the last four digits of your serial number so we can correctly ID which version you have.
Dan tarafından
Yes, some models are harder to open up enough to get the HD's out. Once we know the correct model you have we can clarify how it's done.
Dan tarafından
Hi Dan, the model number is A1347 (it's a MD387LL/A). Is this what you were looking for?
Sky tarafından
No, the serial number. The model number is for all mini's so it doesn't isolate out which one. If your system is running look under the About this Mac More Info... button it should be there or along the side with the model number.
Dan tarafından
Dan, the last four of the serial number are DWYL.
Sky tarafından
2 tane daha yorum göster
