Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2189 Soru Tümünü görüntüle
Soru Kapandı
iPhone EXPERTS - NO Life on phone
Been doing iPhone repair for 4+ years...never seen this, especially on a 4S.
Phone is completely dead. Plugged into wall, computer, Nothing. Swapped battery, nothing. Swapped charge port. Nothing.
No water damage, VERY clean hardly any scratching at all.
Thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
What is the voltage on the battery contacts when you plug it into an AC power source?
tarafından
Don't know. I'll have to grab a voltage meter. What should it be?
So plug the phone in to AC source and touch the battery contacts on the logic board?
tarafından
That is the way I would proceed. the voltage should be somewhere in the 3.6V range. Remember it is the outermost left and right contact.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Maybe the mother board is shot. There must be sum thing amiss on the board solder joints (etc)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I've seen an GSM iPhone 4 do this once before. Customer had it plugged in to charge....Came back a couple hours later and it was off. Wouldn't turn on, iTunes wouldn't recognize, new battery and charge dock did not help....After awhile I stopped trying to get it to work and moved on. Later I was going to put a working board into that frame because of a bent frame I couldn't get straight and the working board wouldn't turn on. I put the board I couldn't get to turn on into the bent frame and it booted right up. It was something in the frame of the phone that wouldn't allow it to turn on. Never did figure out what exactly but if you have another 4s phone sitting around. Try putting the motherboard into that frame and see if it kicks on.
Might be a similar issue to what I had.
Hope this helps!
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 149
