Ana içeriğe geç
A 4GB 3.6" Touch Video MP3 Player by Sylvania.
2 Soru Tümünü görüntüle
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
What does a battery cost and where can one be bought?
tarafından
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
tarafından
Yorum Ekle
It was not working and how to fix it.
Puan 0
1 Yorum:
Um... what are you talking about???
tarafından
Yorum Ekle
My sony walkman wont turn on
Puan 0
Yorum Ekle
Yanıtını ekle
henryr79 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 2,464
