Can I upgrade to 4GB?
Have a 2006 A1176 U35(last 3) Macmini1,1. I saw this answer in one of the past questions: "Officially this only supports 2GB of memory. However, the ability for this particular machine to handle 4GB of memory is well documented."
It was a different model. Does this apply to mine also?
crucial.com only shows a 2GB kit (1GB x2).
Thanks in advance.
David
Bu iyi bir soru mu?
4 Yorum
The statement in quotes was made in March 2012 by ABCellars and confirmed by mayer, regarding a 2007 Model Mac Mini. Mine is 2006 and I was hoping either they or someone knew for sure if it can possibly apply to my model since it's just a year earlier.
David tarafından
1.5 GHz Core Solo (T1200)
Intro Date: February 28, 2006 Disc Date: September 6, 2006
Order No: MA205LL/A Model No: A1176 (EMC 2108)
Subfamily: Early 2006 Model ID: Macmini1,1
Std RAM: 512 MB Std VRAM: 64 MB
Std Storage: 60 GB (5400 RPM) Std Optical: 8X "Combo Drive"
oldturkey03 tarafından
You have to upgrade the EFI from 1,1 to 2,1. AFTER that, you can install 2 2gb modules. If you do not have 2,1, it will not work. Download 2 files to put in, run the commands, and it should work after a reboot and some interesting screen artifacts. Put in an SSD, and a core 2 duo, and these things really speed up!
bwilding2000 tarafından
Bwilding2000 is correct, but the memory controller can only access slightly more than 3Gb of RAM. So compare you mileage of 3Gb (2+1) or 4Gb(2+2) sticks of RAM.
phunguss tarafından
