Ana içeriğe geç
Model A1213 / 8, 16, or 32 GB capacity
216 Soru Tümünü görüntüle
Itunes won't connect with my iPod
Hi there so here is my problem, I have an iPod touch first generation and I just reset it, I also downloaded iTunes for my computer *which is an hp laptop that runs on windows 8*, now when I plug my iPod into my computer iTunes comes up and says it cannot connect to this iPod touch? what do i do to fix this issue? btw it does connect to my computer but not to my iPod
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 20
6 Yorum
"it does connect to my computer but not to my iPod" do you mean that your iPod is recognized by the computer but not by iTunes?
tarafından
I have the same problem but I have a MacBook Pro and it won't connect
tarafından
I just installed iTunes 12.5.4.42 on my ASUS Zenbook/Windows 10 system. Same problem. iPod Touch will not connect to iTunes. Called Apple Support - after a half hour on the phone, and trying the oldturkey03 fix, the Apple tech told me that iTunes no longer works with the old iPods - is this true? Do I have to uninstall iTunes and go back to an earlier version?
tarafından
I have same issue. It looks like Apple ended all support for this device. You will need the cd to get driver or use an old mac running snow leopard to fix the issue.
tarafından
it's a great post admin
https://www.snapseedforpcguide.co/
tarafından
1 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Kendra, the way I understand your question is that the iPod connects to your computer but iTunes does not. If that is so, it is most likely not your dock connector or your cable, and yes, you can try a different USB port. However, I would try with these steps, since it could be a Windows 8 driver issue:"
1. Open Control Panel.
2. Select Hardware and Sound.
3. Select Devices and Printers.
4. Your iPhone or iPod should be displayed in the Unspecified section. Right-click it and select Properties.
5. Select the Hardware tab, then click the Properties button.
6. From the General tab, select the Change settings button.
7. Select the Driver tab, then select Update Driver.
8. Choose Browse my computer for driver software.
9. Select Browse… then navigate to C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers
10. Click Next > Close.
Your Apple device should now be detected successfully within iTunes."
from here. hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 16
19 Yorum:
This was actually more helpful than Apple was.
tarafından
This was by far the best help I could find. You fixed my issue. Thank you so much! Better than Apple.
tarafından
oldturkey03's solution did the trick for me!! Thanks so much!!
tarafından
works like a charm
tarafından
you. are. awesome!!!!
tarafından
14 tane daha yorum göster
Yorum Ekle
@oldturkey03 How you do this on a Mac that does not see an iPhone 3G?
Puan 2
3 Yorum:
@mayer good question.I will try and figure it out if I find my old iPhone 3G I'll give it a try. Easier for me on a Windows machine :-)
tarafından
I'll ask this as a new Mac question tomorrow and accept this answer when it will count.
tarafından
Great job. Worked perfectly!
tarafından
Yorum Ekle
Here is a direct download of old iTunes directly from Apple.
What you want to do is find an old version around 9 or 10-ish.
Right-click the installer, and select compatibility mode for Windows 7.
Install using Compatibility mode.
Right-Click the iTunes icon and also set that to run with Compatibility mode for Windows 7.
Here is a little about the history of the device.
Original firmware 1.0 had nothing but basic functionality.
The 5 apps such as calculator was a package add-on of $25.
The next firmware update was another $10.
The 3rd and last charged firmware update was $10, and included the $25 5-app package.
I think if you have never purchased those, you can reflash an old firmware, but it will not have the 5-app package.
Puan 2
Yorum Ekle
If you can, try a mac or windows 7 computer. Also, you could have a faulty USB port on your computer. It could also be a problem with the dock connector.
Puan 1
Yorum Ekle
You have to download an older version of itunes. First go to applications and uninstall these programs in the following order:
iTunes
QuickTime
Apple Software Update
Apple Mobile Device Support
Bonjour
Apple Application Support (if you have it)
make sure to remove them in that order. Then, restart your computer. Download the last compatible version here:
64-bit
http://www.filehorse.com/download-itunes...
OR
32-bit
find out what version of windows 8 you have first, 64 bit or 32 bit. Install that one, and restore your ipod
Puan 0
Yorum Ekle
Hi:
After spending most of a day upgrading my PC to Windows 10 Build 1803, 64 Bit, and, in the process, updating iTunes to the Windows app version, I was quite frustrated to learn that almost all of the newer versions of iTunes (after about 12.5, including the app on the Windows Store) will not connect with my iPod 1G. %#*@ shame as the iPod continues to work very reliably. I tried several versions of iTunes and a variety of drivers and other diagnostics. Nothing helped - until I found iTunes 12.2.2 at https://itunes-64-bits.en.uptodown.com/w.... I installed that version (run the downloaded install file As Administrator), and presto! My iPod connected and was fully functional. Yay!!
I tried a lot of different approaches but this is what finally worked for me. I hope it is of some help tom others.
Puan 0
2 Yorum:
PS. Don't forget to turn Auto Update off. Otherwise, you'll get an updated version that won;t work with the iPod 1G. :-)
tarafından
Thanks Ron, same boat, exactly what I needed!
tarafından
Yorum Ekle
We have just been speaking with i tunes and they have just told us that second generation is a vintage model so will not be compatable with i tunes 12.1
Puan 0
Yorum Ekle
Yanıtını ekle
Kendra sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 37
Her zaman: 42,280
