Ana içeriğe geç
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Why my controller doesn't connect to my PS3?
I spoiled water on my controller and then the arrows were not working. So I open it and cleaned it up but now, it won't connect to my PS3.. the LEDS keeps flashing and flashing...
Could you help me ?
Bu iyi bir soru mu?
Puan -1
6 Yorum
How did you clean it? Did you check the components while you cleaned it?
tarafından
How I do ? i already tried to reset the controller and its not working with the USB cable ...
tarafından
all the components are fine they have no breaks or anything
tarafından
yes, I was wondering how you cleaned it.
tarafından
with a scott towel
tarafından
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Nicolas, any time you have any electronic component being exposed to water you are running the risk of shortcircuiting any component. I suggest you totally disassemble the controller, after that soak all the components in high grade, preferably anything of 90% isopropyl alcohol. this will displace all the water that may have collected under any of the components. Air dry it after and re-evaluate. Do keep in mind, that just because the components look okay, their internal function may have failed. Not every short circuited component shows external damage. Scott Towels are great for gross contamination, but most certainly not for the microscopic one.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
you may need to re sync it to the console.
Puan 0
Yorum Ekle
Yanıtını ekle
Nicolas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 885
