Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3260 Soru Tümünü görüntüle
after replacing proximity sensor, screen activates randomly.
hello
i followed the guide: Installing iPhone 4 Power & Sensor Cable to replace the flex cable, as my power button did not work at all (btw, seemed that the problem was not the flex itself, but the screws that holded the button, they needed to be unfasten a little, ot it will not work)
anyhow, now the button works perfectly, but the screen looks like it's not calibrated, I click in one area, and itt activates other.
seems I messed up something when I replaced the flex cable, but I do not understand what, as if I broke the digitalizer flex, it should not work at all....
anyhow, any tips?
edit: I used a finger-draw program to see sscreen behaviour and seems that detection on some orizontal areas is missing:
(I can not "paint" in two horizontal bars at the top, looks like it's not registering my strokes)
similar to this, where XXXXX marks the area I can not paint:
|xxxxxxxxxxxxx|
|xxxxxxxxxxxxx|
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
still defective... any hint?
tarafından
Sounds like a bad digitizer. The "wiring" inside the digitizer appears to have failed. Replacing the assembly should resolve your issue.
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would assume you damaged the cable for the digitizer when removing the screen assembly, or when putting it back on. Its very easy to damage if you are not experienced in taking those screens on and off.
There are many tiny wires and leads within the cable, So its possible you damaged one or two by accident and its only affecting part of the screen assembly.
Check the connector and make sure its free of dust and seated properly.
If its still giving you problems. I would replace the screen assembly.
And remember to be very careful when feeding the LCD and Digitizer cables through the frame into the back of the phone. They can catch on the opening and they can be bent at too extreme of an angle and break one of all of those tiny wires causing a bad spot in the digitizer.
Hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
poseido sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 175
