Ana içeriğe geç
The Canon PowerShot A4000 IS is a digital camera offering the user 8x zoom, a 28mm wide-angle lens and a 16 megapixel image sensor. This camera can be directly linked to your computer to upload images and HD video.
How can I fix my camera's "lens error"?
My Canon A4000 IS went through the washing machine, and after drying it out in rice for a few weeks I tried to turn it on. It makes a fast clicking sound and the screen says, "Lens error. Will shut down automatically. Restart camera."
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Nate, couple of issues that you have going against you. Even so Rice is a great first aid, it will not prevent corrosion damage. I would suggest that you disassemble your camera and clean every part thouroughly with isopropyl alcohol and a soft brush, even the lens. Once properly cleaned, check for any further corrosion and missing components. Do not forget the inside of the connectors. Reassemble your camera and re-evaluate. If it still should not work, it is best to replace the lens. Yes, it can be disassembled, but it is very difficult to find parts for the lens mechanism etc. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Nate sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 3,560
