Ana içeriğe geç
Why won't my iPod connect to my mac?
I had the motherboard replaced yesterday but now it wont connect at all to my mac. Tried every usb port and it won't even show up in disk utility. Plugged it into a wall socket and it charges as well as using multiple cables
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
joberteugenio, if it does charge on an AC charger but not your USB port could be related to a bad battery (Your AC adapter supplied a higher amperage than your USB ) or a bad dock connector (since you already changed the cables and the USB ports on your computer) I would double check with the place that replaced your logic board to make sure this is not something related to the workmanship. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
joberteugenio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 131
