Is the battery still good?Accidently 2 cable touched and sparked
While installing the battery, 2 cables touched(don't remember which ones) and it made a small spark.
I couldn't be successful installing the battery in my ipod Nano 1st generation because while using a safety pin tip in one of the whole it got stuck and when I pulled, I pulled out the ring around the whole and severed the connection, so, no way to know if the battery works...
:( was my first attempt at fixing... looks like I need a new logic board or maybe cheaper to get a used ipod...
I added the rest of the story so you understand why I'm not sure if the baterry is still good after the cable touched and spark, while I'm thinking about getting a new logic board, but if the battery is fried, then it's no use...
Thanks
Bu iyi bir soru mu?
What model is it?
oldturkey03 tarafından
the model of the battery is:
PArt No. NWTBIP0D380M1N
3.7 Volts 380mAh
Rechargeable Li-Ion Polymer Battery
From Newer Technology
NuPower Replacement Battery for Ipod 1st Generation Nano Models
rob tarafından
so it is a Nano 1st gen? Yes, the battery is most likely still good if you just drew one arc from the battery cable. your original question mentions a iPod Touch while you say your battery is a Nano Battery. It does sound like you tore your solder pad. If it is a touch, you can may be fix it by placing a jumper. Which iPod is it? Clarify your whole story for us. Which pad did you tear off?
It's a Nano 1st Gen.... the pad I tore up is for the black cable
rob tarafından
