Ana içeriğe geç
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Soru Tümünü görüntüle
no sound from output or speakers
I get no sound from speaker or form output on macbook late 2008 unibody 2ghz,but i get sound from headphones on bluetooth.what is the problem. help
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The headphone socket has a small switch inside so when you remove the plug the internal speaker is driven. It sounds like you may have a dirty switch or damaged it with a mis-shaped plug or just from a lot of use. Using a dentist probe and a magnifier see if the switch is working and if needed try cleaning it. In some cases the switch shifts so the contacts don't touch using a toothpick try rotating back the contact. Use the Mic outlet as a guide as it's the same socket.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Floyd Thomas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 237
