Cannot find Wifi card after re-installing the card
Got issue with the Airport Card and replace the card. However, now it even not detect the card at all. Anyway, I can manually install the software to activate?
Bu iyi bir soru mu?
İptal Et
Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
İtibar: 1
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınSorry Rick, it sounds like you have a bad AirPort card and/or the connector on the system board is broken so it's not being seen by the OS.
You could try resetting the PRAM Apple TN on NVRAM & PRAM to see if that helps. Otherwise you'll need to try another card and inspect the connector and the cable connections.
If your logic board is damaged I would recommend looking for a USB connected WiFi adapter (make sure it works with the Apple OS you are running on your system).
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 163
