Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
Why does my iPhone has some grey spots on the screen?
I have accidentally fallen on my iPhone and hit on the screen with my elbow. I have noticed some grey spots on my display now.
These grey spots (5 of them) are visible on the screen even when the phone is on standby mode. These grey spots are not always in the same shape too.
The screen is intact and the touch functionalities are fine too. The touch on the grey area is also getting recognised fine.
I had thought of changing the display but when am noticing that these spots are becoming smaller, now I dont know if its a good idea to change the display.
Can someone please tell me what should I do now regarding these grey spots?
Bu iyi bir soru mu?
Puan 3
9 Yorum
Hi, I have tried to rub on those grey spots and they seem to move. I have succeeded in rubbing those and made them to move till the sides of my phone from centre. But they dont move out completely.
tarafından
Hi, Can these be dead pixels??? If yes, then how should I get my iPhone display back to normal.
tarafından
I have the same problem... should i change the display?? what should i do?
tarafından
I would think that they are dead pixels and would consider changing the display. It would also work a lot better for you if you ask your own question and give as much detail as you can. There is a link on the right hand side of this page "Ask a question" and if you click on it you get to tell your story and tell us what happened and what you did to try to fix it. Right now your question shows up as an answer to an old question. Good Luck and give it a try.
tarafından
look my iphone has gray spots but it wont take off do u guys think that apple could fix this problem
tarafından
4 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi, thanks for your response machead, I waited for am answer and later I have got my screen fixed at a service centre.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You can try this
http://knoxing.com/2007/08/05/iphone-stu...
Puan 1
Yorum Ekle
i also accidentally fallen on my iPhone but in beginning there was not a spot but gray lines appears, with the passage of time its become on big spot now its is turning smaller i guess the usage create this i am totally agree with this " rubbing formula" and i am on it, if line become spot and spot become smaller then may be its remove or move to the screen corner.
Puan 0
Yorum Ekle
idiot
Puan 0
Yorum Ekle
It is broken. You need to replace a new one.
Puan 0
Yorum Ekle
On my ipod I hit it by accident and on the top you can see colorful spots with red,yellow, and green I need help. Will it go away
Puan 0
Yorum Ekle
Ignore Bob, he's an idiot for trolling
Puan 0
Yorum Ekle
Yanıtını ekle
Raju sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 79,340
