Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 Soru Tümünü görüntüle
iPod is locked and says try again in 22,353,345 min.
my ipod 4th gen is locked and i am computer illiterate. dont even know how it got the lock put on it except my little brother messed with it while i was at work. i am upset none the less cause i dont know what has happened. i set it up on my moms comp. so i dont have access to it someone please help
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Rpbert Miller, here is what apple says :"
You may be able to reset the passcode by restoring the device.
Connect the device to the computer with which you normally sync and open iTunes.
Note: If iTunes prompts you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes", below.
Right-click the device in the left column and select Back up.
When the backup is complete, select Restore.
When finished, restore from your most recent backup.
When finished, restore from your most recent backup."
If you do not have access to the computer you normally use to sync, follow these instructions.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Robert Miller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 104
