Ana içeriğe geç
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
163 Soru Tümünü görüntüle
Can not remove Phillips screw on RAM access door plate
am trying to replace the intern hard drive on this 2009 24 inch iMac but the Phillips head screw that secures the RAM access door has lost its grooves and the Phillips head screw drivers cannot loosen it. How can I remove the screw?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Depending on how stripped the screw head is, you could try fitting a small piece of paper over the tip of your screwdriver to fill the gaps between it and the screw head. Another trick is a rubber band, but that works for bigger screw heads.
Hope you get it out!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
fbloom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 201
