The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
701 Soru Tümünü görüntüle
Fan goes crazy when PS3 is turned on
Please help me, i teardowned a ps3 yesterday to clean it from dust, i didnt touched/destroyed anything. Inside the PS3 i just used a brush to remove the dust, then when i turned it on. The fan went into a overdrive, going all crazy, then after like 10 seconds it shutsdown.
And it keep repeating itself all the time, its a CECHL004
i have tried to replace the fan with another one, same problem occured, i replaced the PSU (power supply unit)
cause i tought it got to much voltage and the fan tried to keep up?
i changed it all back, but it still goes crazy please help me, i really want to fix this problem :(
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you repaste the CPU and GPU? If you did not do this that's why your PS3 is going into a protection mode. The idea is it prevents the CPU and GPU from getting damaged, since not having thermal paste prevents proper thermal transfer. I'd suggest new thermal paste before you do anything else.
Assuming the system was taken apart (or you don't need the guide again, here's a rough idea of how to do it on the PS3:
update
Try doing this to fix the Blu-Ray issue. If it doesn't fix it it's the laser.
PlayStation 3 BluRay Laser Replacement
If you need it, here is a new drive you can get.
http://www.ebay.com/itm/NEW-SONY-PS3-Blu...
PlayStation 3 Blu-ray Disc Drive Replacement
PlayStation 3 Blu-ray Disc Drive Resmi
Kılavuz
Zorluk:
Orta
15 minutes - 1 hour
PlayStation 3 BluRay Laser Resmi
Kılavuz
Zorluk:
Orta
20 minutes
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
I put new paste ón yesterday and it worked :) you know why my blue Ray disc drive wont work after YLOD tried everything i Got 3 other blue Ray disc drive but it wont work :(?
tarafından
Yorum Ekle
Yanıtını ekle
Danni sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 11
Her zaman: 2,079
