Ana içeriğe geç
Repair and disassembly guides for adapters of all kinds.
Battery Charger to hel test if it's a bad battery or a bad power jack
I do computer repair. I was wanting to know if they have a device that can charge any laptop battery externally. In my troubleshooting I want to make sure I'm not dealing with a bad power jack that's not charging the battery or not charging it right. I want an external device to determine if I'm just dealing with a bad battery that needs to be replaced.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Good question! Sorry no.
The problem here is each different LiOn battery requires a different charge cycle & connection just within the one manufactures collection of systems it sells (Apple alone is around 20 different batteries).
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
The best way is to use a Ohm meter to check the connectivity, and a Volt meter to check the voltages of the circuit pathway.
tarafından
Yorum Ekle
Yanıtını ekle
Dan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 247
