Ana içeriğe geç
Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
959 Soru Tümünü görüntüle
How can I realize which part is broken?
I droped coffe on my iPod.
My iPod classic 80GB has red x.
so I want to replace HDD and If i can i want to
upgrade my ipod classic 6th 80GB to 160GB.
How can i realize which part is broken?
I tried Diagnostic Mode.
so SDRAM FULL TEST said plug in FW to start No Power supply.
SRAM said Test Pass.
Harddrive test said can't open HDD.
Could it Hard disk problem?
Is there any possibilites?
Is there a possibility of Logic boad problem?
I'll buy
HDD (mk1626gcb or HS161JQ)
160Gb's back cover
160GB HDD connector
iPod Classic 160GB thick Back Cover (with headphone jack and USB dock assembled)
160GB HDD connector cable
iPod Classic 160GB Battery
Is it enough?
Thanks.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
When i opened iPod, It looks no flooded.
tarafından
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
koji, the "classic 80GB has red x." is usually caused by a bad hard drive. Take a look at the hard drive connector and the HDD cable, for any damage. The best way to determine this would be by placing your iPod into disk mode and see if your computer can find and access it. Right now it does look like a bad hard drive. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
Thanks for answering my answer oldturkey03. I tried disk mode many time. but i couldn't enter disk mode.
tarafından
Sure sounds like a bad hard drive. Thank you for accepting my answer.
tarafından
Thanks very much!! I'll buy MK1626GCB.
I'll try it!!
I wish Logic boad dosen't have problem.
tarafından
I searched about iPod classic 6th 80GB upgrade.
so i found that could I then put the 160gb hard drive in my 6th generation? Would it only read 128gb max?
can't my iPod read 160GB?
tarafından
It should read it for as long as it is a drive that has the right connector and the right interface.
tarafından
Yorum Ekle
Yanıtını ekle
koji sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 638
