Can a bad processor cause red rings
can a bad processor cause red light flashes.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
rhonda, sure it can. "RROD is caused by anything that fails in the “digital backbone” on the mother board. Also known as a core digital error. CPU, GPU, memory, etc. Bad parts, incompatible parts (timing problems) bad manufacturing process (like solder joints), misapplied heat sinks or thermal interface material, missing parts, broken parts, parts of the wrong value, missed test coverage. Any one or more, on any chip, or many other discrete components, would cause this. And many of the failures were obviously infant mortality, where they work when they leave the factory and fail early in use. The main design flaw was the excessive heat on the GPU warping the mother board around it. This would stress the solder joints on the GPU and any bad joints would then fail in early life." from here as well as many other places. That is why a secondary erorr code is just as important. Check on here for more information on that. Hope this help,s good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
rhonda sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 80
