problem: ipad mini 4 not charging or booting up. red lines with battery symbol and apple symbol would cycle over and over again and nothing would happen. Ipad was plugged in.
I tried holding the sleep and home buttons for long period and nothing happened and then holding the same buttons and then releasing them over and over again but nothing happened.
I tried restore and update in recovery mode and dfu mode in itunes but neither worked, just errors every time.
I even tried putting the ipad in the freezer for an hour.
(By the way... if you are stuck in itunes connect mode after a failed install or restore, u can download fonelab which will take u out of itune or recovery mode)
I tried different chargers and cords and leaving the ipad plugged in over night.
Nothing worked so i decided i would get some revenge and beat the $@$* out of it. I put the ipad on the floor so i could hit the screen with my heel. just kind of fooling around but a bit annoyed too. So i hit the thing on the screen while it was plugged in and i kid you not... it paused for a moment on the apple logo screen and then booted up.
so, clearly the problem is a hardware issue. I updated the operating system after that which didn't help anything. And now the ipad will turn on and i can use it but it doesnt charge and i have to use it in the same position and not move it too much or it powers off.
Im going to look for solution for it not charging now that it turns on.
The problem is obviously and most likely the charge port or some other hardware issue.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
34 Yorum
we have the same problem. have you fixed it already?
rhona tarafından
I have the exact same problem except my iPad shattered and t was working fine everything was working perfectly after it shattered but then 2 days after I came home from piano and it wasn't turning on at all I tried everything nothing? What is wrong?
Emma martin tarafından
I've tried holding the home and turn off button and still not working
kieran tarafından
I have a first generation iPad which is indestructible and too an iPad mini which I have had for approx 14 months. Yesterday the mini died. I have tried all the recommendations with no resolution. It appears that from the 392 posting s on IFIXIT that surely this has to be a known issue by Apple. I am disappointed that no announcement has been made by Apple to my knowledge . I'll be taking the mini critter into Apple to hear my verdict! Long live the First Generation!
jamesalfonsomartinez tarafından
I have the same problem. I went and put my ipad mini in my room and after one minute I went back in and tried to turn it on but it wouldn't turn on so I put it on charge but it would work and I have tried the power and home button so. What do I do?
alysha meade tarafından
29 tane daha yorum göster
