Ana içeriğe geç
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Soru Tümünü görüntüle
replaced front panel, after put together picture all haywire
to put a more accurate description after I tried fixing a cracked screen on an iphone 4 for Verizon - the screen is all messed up. theres faded lines faded color you can read anything. I should also add that during installation I accidentally ripped the digitizer cord could this be the problem? thanks!
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
David, "ripped the digitizer cord" is possibly causing your issues. Make sure that the LCD connector is properly seated and that you do not have any bend pins or debris in the connector. If all of that looks okay, it is possible that you received a bad display. Try again, a bit more careful, with a new display.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
[deleted] sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 83
