Machine won't boot, Graphics card fan running at full speed
My 2009 quad-core MacPro suddenly turned off over night and does not start up anymore.
When I try turning it on the graphics card fan immediately spins at full speed. CD and HDs are being initialized. The other fans are running at normal speed. Logic and CPU board LEDs are turned on.
I'm not getting a chime on startup nor any picture on the screen. I cannot reach the machine via network either, so it does not seem to boot at all.
I tried the usual procedures: PMU Reset, NVRAM reset.
Anyone has an idea what's broken?
Bu iyi bir soru mu?
1 Yorum
Your post and solution give me great confidence. I have exactly the same issue. When I pulled out my processor tray I could hear the plastic clip/screw and spring rattling. When it rolled out and I googled it I found your post. I cannot believe it. It seems that several owners have had this problem. My one concern is that the northbridge is fried because the sink had been off for a while, and the loss of the chip is really what killed the machine. But this was clearly not the case with yours. Perhaps there is electrical continuity between the fastener points on the sink and the machine knows if it pops off.
David Scrofani tarafından
