Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
Volume button screw is stripped
I've been following the instructions to replace the rear panel on an iPhone 3G I'm experimenting with but when I came to remove the volume screws on the inside (4 of them) the middle one is well and truly stuck and I think I have now stripped the screw back through sheer frustration. Any hints?
VMT
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
small drill bit and drill the head off. then you can just pull the screw out with some little tweezers etc. there are other suggestions on here...just search for stripped screw. try the next size up PH or get a flathead instead?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Aaron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 78
