Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
768 Soru Tümünü görüntüle
White Plastic around charge port is broken and iPod won't dock.
Theres a piece of white plastic that surrounds the charge port on the Ipod. Half of the plastic broke off on mine and now the speaker dock won't detect it when docked. I can still connect it to the USB cable however. Does anyone know if this white plastic piece can be replaced?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The broken plastic is most likely what allows/forces the connection to stay just where it should be. A cable/USB cable doesn't have the same problem as it's made to fit snug at any angle.
You may need to either find a replacement casing for the ipod, or put something on the dock that it can lean onto to be pushed back to where it should be. It only needs to be a tiny amount off center to not be able to work properly.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Blake, the plastic bezel part is available at places like this and many others. Hope this helps, good luck.
Puan 1
Yorum Ekle
Yanıtını ekle
Blake sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 230
