The agitator won't turn very well.
If I put pressure on the top of the agitator it turns better, but if I let go it just moves a little. Still works just doesn't wash clothes very well.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sunita Contreras, it is possible that the clutch dogs have worn so much that the washer no longer agitates properly. The agitator is removed by first pulling off the gitator cap and inner cap. then unscrew the 7/16" bolt founf under teh cap and pull straight up on the agitator assembly. the clutch and cluthc dogs that provide the agitator action are found in the upper portion of the agitator assembly. Check this video and get the service manual from here. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,025
