Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
1133 Soru Tümünü görüntüle
Will isopropyl alcohol be safe on my lcd monitor?
Have some adhesive on my lcd from peeling off the glass component, will isopropyl alcohol be a safe solvent to clean it off?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Make sure you get a good quality alcohol as some cheap stuff has other solvents which can cause damage or it leaves a film of junk when it dries. Best to get 85% or better, reagent grade being the ideal (no junk in it).
Wet a cotton swab with the alcohol. Don't over do it, as you don't want the alcohol is seep into the works.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
I agree with everything but the percentage you mention. For cleaning things like this or electronic boards use Pharmaceutical grade 91% or better. If you can't find it on the shelf the pharmacist will have it behind the counter or you can by it on line. I realize that you are thinking there is not much difference between 85% and 91% (available at Walgreens) but, there is insofar as contaminate content. I use 99% for things like this, final clean on boards and in my flux formula.
tarafından
Yorum Ekle
Yanıtını ekle
Mitchell Davenport sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 Gün: 32
Son 30 Gün: 188
Her zaman: 5,190
