cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Unplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
Bu yanıt yardımcı oldu mu?
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
After turning power on I push the start button and hear a humming noise. Please help
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,097
