Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
913 Soru Tümünü görüntüle
Soru Kapandı
Drop iPod in sea water.
==I have rinse it and let it stand in rice for48h is there anything else I can do?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Judith Fortin, here is my answer to a very similar problem :"please remember that rice is only a first aid. It will not prevent corrosion nor fix shorted SMD components. At this time my advice to you would be to no longer try to start or charge your iPod. Remove the battery, and disassemble it right down to the logic board. Use the teardown to assist you with that. Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Check for any burned or missing components. You may have to repeat this step a couple of times. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. Right now, everything will only be a guess, and the longer you wait the more corroded it will get. Hope this helps, good luck."
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 79
