broken glass digitizer replacement
This is my first time into a ipad & I picked a mini. My first soldering of a flex connector went pretty well. My problem is the bottom inch of the digitizer, when holding the unit vertical, does nothing. Otherwise the digitizer seems to work well. Should I try to resolder the flex to the digitizer board. What end of the cable controls the very bottom of the digitizer.
What is the glue that is used in the unit,I have the double sided tape but the home button does not stay in place with it.
Thanks
Tom
Bu iyi bir soru mu?
