Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
Doesn't boot, only the chiming sound and it freezes.
My MBP doesn't boot. I can hear the chime, it starts to load OSX, but after about 10-15 seconds it freezes.
When i try to boot in Safe boot mode, it works well.
I've tried to reinstall the system from an usb pendrive and from an install dvd also, but i experienced the same like when i try to boot normally. ( Chime, apple logo, and it freezes after 10-15 seconds )
In verbose mode i didn't see any kernel panic, the loading stops in various operations.
Does anyone have an idea what could be the problem?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like disk failure or OS corruption. Boot from a repair disk and run DiskTools->Disk First Aid:repair disk, and repair permissions. You could run AHT 2 or 3 times to see if it detects an error (often running AHT only once finds nothing wrong).
If this Answer is helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Here is what i did until now:
-SMC reset
-NVRAM reset
-I formatted the HDD in an other mac, the disk seems to be ok.
-I am unable to run AHT ( Nothing happens if i push the D button )
-when i try to boot from an osx install dvd or a repair disk, it freezes again during boot.
tarafından
THat might be a bad Optical Drive... can you boot to an external HD with an OS on it or from a Target Booted other Mac?
tarafından
Yorum Ekle
Yanıtını ekle
revengangel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 231
