These particular PSUs fail because of bad factory work.
They would need to have been properly flowed in the soldering process at factory.
$@$* like this is what makes us lose faith in Apple.
How can they dare ship MacPros with these dodgy PSUs, and won’t get them replaced, they’re so smart as to never ever let them die within the guarantee period.
Then they suddenly fail. Almost always just after the period ended.
$@$* PSUs, I guess Delta (the provider) is using monkeys in the soldering plant at their factory.
And eBay sellers are just making a profit on selling replacement units that maybe are just refurbished units that will fail also given enough time.
We gulp this and cope with this because of a brand’s undeserved reputation.
It’s all been a money drain since Steve Jobs left us.
Apple is no longer a winner game, it’s all bells and whistles but they don’t care about the power going to their MacPros. Please take the Pro nickname out, it’s not deserved.
They put us through all this $@$*, this hoops because they want us to obligue and not use our 2008-2010 MacPros anymore, they need to make a profit from us, they need to get us to buy a new “umbrella-cube” 3k-4K machine just because.
Btw, it’s all about the soldering quality from factory, the damned relay switch inside the PSUs, and/or the temp sensor &&^&^$^ with all the security settings for switching it off just because.
No one wants to determine the real culprit because mos people are better off selling you a 200 or 300 bucks replacement.
Technical progress has become only a money drain and a huge waste of otherwise repairable units. Obsolescence and customer-obliguing tactics are the norm. No one cares anymore and they just are waiting for us to shell out the cash for a psu which could probably be repaired for ten or twenty bucks.
Welcome to never ending progress and never ending dissatisfaction.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
4 Yorum
great way to ask a question +
mayer tarafından
Have you checked your ram. Your Ram may have failed. Try changing one piece or take out some stick, until you find it will boot to the apple logo
glen street tarafından
i tried take out some and i removed them all too nothing happen
Mansoor tarafından
The end of the Memory Cpu board slides in first the back end, There are 4 little Capacitors on the left side they go in first (They are very small 1/4 in. or less make sure one didn't Break off or one of the 2 wires on each one come loose or break off, that was my Problem, Couldn't believe that little thing affected the whole Computer, Third one had one wire broken off I guess from sliding in, Check it. Good luck
Michael tarafından
