Boots when charger plugged in
Macbook A1181 2.16 GHz
Rebuilt a Macbook as the bottom case was badly damaged. Everything is connected OK, fan magsafe etc.
The issue is when I plug the magsafe in from the macbook being off it boots automatically without touching the power button.
tried resetting PRAM etc but still have the issue.
Bu iyi bir soru mu?
6 Yorum
Can you take some hires pictures of the damaged case bottom and the area that got the hit so we can see what happened? It sounds like something got damaged case causing a short.
Dan tarafından
No damage around magsafe area, damage was superficial and all parts swapped were the ones from before that worked fine.
kelvin stephenson tarafından
Please download and run Coconut battery and let us know your results, Thanks: http://www.coconut-flavour.com/coconutba...
mayer tarafından
tried different topcase, checked the sockets, still the same. Then all of a sudden it just started to work normally, no idea why.
What did Coconut battery show?
mayer tarafından
1 tane daha yorum göster
