Yes - from safe mode make a new user account and set that as the log in account. You have some corrupt files on your old main user account.
No, i said put them back one at a time (you'd already removed all and found your machine would boot) Your problem is in one (or more) of the following:
- an extension safe boot loads only required kernel extensions (some of the items in /System/Library/Extensions). You can navigate to that library after a safe boot and look at what is left in there The "disabled extensions are potentially one of your problems".
- Mac OS X v10.5.6 or later: A Safe Boot deletes the dynamic loader shared cache at (/var/db/dyld/). A cache with issues may cause a blue screen on startup, particularly after a Software Update. Restarting normally recreates this cache.
- A fonts other than those in /System/Library/Fonts (Mac OS X v10.4 or later). One of your peripherals may have installed a corrupt font.
- A font cache normally stored in /Library/Caches/com.apple.ATS/(uid)/ , where (uid) is a user ID number such as 501 (Mac OS X v10.4 or later). One of your peripherals may have created a login item that is hanging
- A startup item or login items (Mac OS X v10.4 or later).
I would verify your disk, and repair permissions while in safe mode. I suspect you have a liquid damaged HD.
I would also run Apple Hardware Test to see what problems it finds.
If this Answer is helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
Please give us the last three figures of your serial number.
mayer tarafından
