1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
186 Soru Tümünü görüntüle
Power button is non responsive
I have a MacBook Air that stopped powering on. I opened up the back panel and disconnected the battery pack, reconnected the battery pack, and plugged the power adapter into it. Now my MacBook boots into the OS, but the power button is non responsive. If i shut it down I will not be able to get it powered up without running through the above steps. I don't want to do this everytime it dies, or gets shutdown.
The question I have is, will I need to replace the entire upper case to get the power button repaired, or is there just a power button with a ribbon cable/switch that can be replaced instead?
Any help would be greatly appreciated, thanks.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You might be able to find just a power button on e-bay (or elsewhere), That would be an advanced repair... the easy DIY fix is to replace the top case.
If this Answer is helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Chris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 185
