Doesnt slide to unlock phone
After I changed my screen it wont slide open any message nor will it even read my finger only voice control works. I need help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Marcus, make sure that you double check your work. Make sure that the digitizer cable connector is properly seated, check for any bend contacts. If all that checks out, you most likely have a bad digitizer. Speak to the vendor and ask for a refund, replace the display assembly once more. Here is the guide for it. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 134
