Ana içeriğe geç
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Soru Tümünü görüntüle
Soru Kapandı
power button not working
Hello everyone,
I recently replaced a screen digitizer for an ipad 2. It was cracked. I have done a fair amount of these and I know you have to be careful with the ribbon cable for the power button not to rip it on removing old screen. The cable appears to be fine, but i cant shut this thing down. The new screen works fine, mute button works, just not power. I assume I may have to replace power button. Does anyone know of a way to power the ipad off so i can replace the power button?
Since the actual power button can't be used to power down iPad. Any help would be awesome. Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
I wondered about disconnecting battery. You feel like you should always disconnect battery on all ipad repairs? It never says anything about disconnecting battery in a lot of the other iPad repair manuals from ifixit. Like for a cracked screen or LCD replacement you should go all the way and disconnect battery?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Your only 2 options are to let it discharge on its own or disconnect the battery, which you should do with any repair to begin with.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi,
For anyone who needs to switch off an iDevice with a defective power button, just go to Settings > General > Accessiblity > AssistiveTouch.
Done !
This black touch button has all you need to control you iDevice.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,699
