Ana içeriğe geç
Apple's line of MacBook Pro laptops was intended for the professional and power users. The MacBook Pro line includes the MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", and the MacBook Pro 17" Unibody.
15106 Soru Tümünü görüntüle
MacBook Pro will *only* run with disconnected battery
Ok, so, my friend spilled a scotch and soda on his mid-2009 Macbook Pro, and I'm trying to suss out the extent of the damage.
The computer will boot and run normally off of AC power with the battery disconnected. With both the battery and AC adapter connected, however, the it will shut down halfway through the startup sequence (after the chime, but before the grey Apple logo.) Furthermore, if I reconnect the battery while the machine is up and running, it will shut off immediately.
(Also, the battery test button does nothing, no matter what is connected or not.)
So the question I'm left with is whether it's the logic board's battery-in port that's problem, or if it's just a bad battery. Obviously, the ideal next step would be to see if the machine starts up with a known-good battery in place, but I unfortunately do not have one to try it out with, and I'd rather not spend the money to buy one, only to find out that it's useless because the MBP's logic board is faulty.
What do you think the likelihood is that it's only a faulty battery causing the shut-downs? Is it worth risking the $150 to find out? Or is it pretty much certain that the logic board is bad?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Some of these laptops will not boot with a bad (-25% charged) battery. But will boot and run slow off the charger only. Examine the logic board around the battery connector under a magnifier for corrosion or burnt/swollen components.
At that age a new battery would be appropriate. I guess you'll have to price out the cost of fixing the port/logic board vs just a battery.
If the new battery isn't the fix you can part out the machine and the new battery to recover some $ for a new(er) laptop.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Jaime sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 6
Son 30 Gün: 23
Her zaman: 3,036
