Is it worth fixing up my MacBook Pro 13" Mid 2009?
MacBook Pro 13" Unibody Mid 2009 2.53 GHz Core 2 Duo processor 250 GB Hard drive 2 GB RAM Running Mavericks version 10.9
My Macbook Pro 13" Mid 2009 has been causing me several problems lately, and I'm curious about whether it is worth spending the money to fix.
Current problems:
-Battery status is "Replace Now"
-It is really, really slow. I'm thinking this might be a RAM issue, but I am unsure. I don't know how to gauge this from the new Mavericks Activity Monitor design.
-Trackpad does not allow me to press to click, I can only tap to click (i.e. I cannot physically press the trackpad to click, I can only tap the surface)
-Occasionally (once every two weeks) will have kernel panics that will cause it to reboot. I do not know what causes these, no discernible pattern. When it reboots, the internal clock resets to January 1 2000.
Any and all advice would be helpful. I have not opened up my laptop ever, but feel competent enough to do so if it will be worth it.
I'm hesitant to try fixing it if people think it won't work, because costs are fairly high:
-$100 to buy two new 4GB RAM chips if I upgrade from 2 to 8 gig
-$112 for new battery
-$10-$20 for tools to open up my laptop/duster can
TOTAL: $250 just in upgrades
However, it's cheaper than a new Mac if you guys know that these things will resolve some of my problems! Thanks in advance for the help, please feel free to ask questions if you need more info
Bu iyi bir soru mu?
4 Yorum
Sometimes one can find a replacement at reasonable cost on Craigslist, & sometimes it can be both an upgrade as well as a working replacement. But U & the seller must be willing to do a thorough check before you decide.
lumloy371 tarafından
It’s worth upgrading I did my mid 2009 Pro to 8 ram 120 ssd works great and fast
Docota runningwolf tarafından
I have a Apple MacBook Pro 17 or 15 inch that has this message and I can’t get past.. is it fixable? Choose start up disk no disk available.. then window you can’t change the startup disk
3gangels tarafından
Yea, I suffered the same. Changed the SSD cable (50usd) that connects the motherboard to hardisk that created the kernel panic issue, changed by battery (150usd) Working fine now.
30dayartist tarafından
