Ana içeriğe geç
Repair and disassembly guides and support for dish washing appliances.
287 Soru Tümünü görüntüle
Why my dishwasher is stucked in a program?
Hello there, my dishwasher stucked in a program, and don´t receive water or expell it, just make an repetitive and very short noise, like is starting an program (vvvt vvvt vvvvt :))
Hoover Nextra - HND6515A is the model
Ty for all your help
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn’t overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Mine stopped mid program and wouldn't heat the water and so stopped. Not sure if that helps yours, but here is my video of the fix
https://youtu.be/o6vzTzUm7d4
Puan 1
Yorum Ekle
Yanıtını ekle
megamoka sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 6
Son 30 Gün: 111
Her zaman: 5,620
