My iPod Nano is Frozen?
iPod froze, ive restarted it multiple times by holding in the center and menu button, and installing the new software, ive let it die 4 times and charged it back to 100%, how do i get it to unfreeze?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Are you checking hold switch and doing steps below
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Now press and hold the Menu and Select buttons until the Apple logo appears, which may take about 6 to 10 seconds. You may need to repeat this step''.
Bu yanıt yardımcı oldu mu?
yes I've tryed that multiple times, still doesnt work, like when i reset it and installed the new software it brought up the page where it asked you what language you would like and i cant click anything cause of the clicking wheel is frozen or something the only way i can listen to music is by shaking the iPod. nothing else seems to work
you are a genius! thank you so much :) it would of have been hella embarrassing for me to tell my mum i broke her ipod :/ THANK YOU :3
well I have tried at least 50 times and my screen just says eject before disconnecting and I am preaty !#^&@@ of and I won't have a apple computer for a a week or two please reply at koven49@gmail.com
Thank You
Thank you so much, I was really freaking out just now.
Thanks so much! I was worried I was gonna have no music for my holiday in 2 days time and no money to but a newer ipod etc - simple fix!
take it in to Apple...they may or may not charge you to fix it.
it's a pretty common nano 4g problem - but they are only similar and there is no common answer to that.
some can be fixed with scotch tape on the click wheel, others work when the click wheel is replaced (but not all), then a few work if the click wheel connector is cleaned and so on.
i have one of those frozen nano 4g that won't work with the "common tricks" - maybe i order a replacement part and try that.
the "fun" part is, that the touch sensitivity is still there - if the iPod "sleeps" and you slightly toch it - the light goes on
haha yeaa, i think im just gonna go buy an iPod touch or something
I think this is the best way before taken it to Apple store or centre.
thats what brem suggested - that's working on the nano 4g - that is the only thing what always works - the rest of the click wheel is still unresponsive. and many nano 4g are out of warranty - so apple won't fix anything on them - except selling you a newly refurbished one for the price of a nano 5g
yea ive done everything you can think of
and mine is out of warranty also,
which is bullcrap cause i didnt cause this to happen,
it just did
Okay you try this step on different OS
For example, if you try this step on OS X maybe try again the step above from windows
lol - what OS?? are you aware that the steps you are referring to are done without a computer?? and btw - i restored the nano 4g on 7 and 10.6.2 - worked without an error message on both systems. please don't copy and paste the same stuff twice as an answer - especially when someone already postet it 2 weeks earlier!
correction.. i mean this step u have to do with your nano connected to PC then try the step..
and then try to restore the firmware from itunes
if i remember right: to get into dfu mode hold select+menu until screen goes off and then press select+menu again (itunes must be running)
Thank you mark from about a decade down the line. This comment allowed me to repair my old ipod with ease!
yes that is definitely right.. then will iPod auto reboot itunes will automatically detect it then it will show on itunes.. from there you can restore hope it work for those froze iPod.. and this step can be use on all iPod..
I have that problem with the 4g nano. I have replaced the click wheel but it does not working. I have test the click wheels (both of them new and old) on an other 4g nano and they are working. I can do hard reset with the click wheel. And I can open ipod up when press the buttons. But it cannot respond after the ipod turned up. I can not login the diag. menu!!
Sorry for my english.
Regards.
The wheel on my Nano doesn't work. I've tried re-booting it and unlocking it.
How much is apple going to charge me?
Mike
NYC
Feb 2011
It would be a lot easier for you to ask your own question if you expect some assistance with the problem. Nobody sees your question since it is tagged as an answer to a 10 month old question.
FFFFF. I don't have an answer, just another question. I'm not sure if this the problem you all have been talking about, but my iPod, fourth generation, out of warranty(duh), refuses to work. The screen is frozen, but the music will play, it still responds to touch, I can put in/take off music, which means it also appears in itunes. I've restored the stupid thing, reset it manually (and after all that, it will NOT respond to being turned "off"). The screen mainly stays on the Apple Logo (because I've been resetting it), but once in a while, it will change to what the actual ipod is on (like I said, it still responds to touch), but when I try to do anything, it's frozen again (but I can still use the music, provided I can even navigate thing blind). Once in blue moon, it actually WILL work, the screen, I mean, but that usually lasts 5 seconds before it freezes again. The HECK is going on here? And what should I do about it?
It would be a lot easier for you to ask your own question if you expect some assistance with the problem. Nobody sees your question since it is tagged as an answer to a 10 month old question. Submit
Your best choice would be to sell the 4g and get a mp4 player from archos or samsung or sony . They are a lot cheaper and you can do a lot more with them
i bought 2 of these nano ipod4th gen 8gb from ebay..both with track pad problems.....i got onto ebay and bought 2 new trackpad ribbons (they look like a very fine printrd ribbon circuit) took my ipod to bits(instruction video on you tube)fitted the new part and works great
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 34,831
