Power & home button not working after battery replacement
I received my replacement battery today, and after getting it installed, I immediately noticed that the power and home buttons are no longer working.
I used the usual suction cup method, rather than a feeler gauge (that I've been using now), with A LOT of force that might've damaged something upon opening the screen. I noticed that the LCD display has some bleeding (not sure how to explain it).
After checking all of the cables, everything looks normal, though.
Everything else about the phone works fine (LCD, digitizer, silent switch, vibrator, both cameras, volume buttons, Wi-Fi/etc.).
Any ideas?
Update
I ended up getting an iPhone 5s (maybe I should break phones more often?). Seriously though, I'm still angry at what happened.
I adjusted the angle of the 2 home button pins a number of times, and it just wouldn't work.
I'll let the new owned deal with it. It's currently selling on eBay
Bu iyi bir soru mu?
9 Yorum
Any one got an answer? I have the exact same problem. My local competent installer reckons the motherboard is the problem to these two issues
Liam tarafından
Wow this must be a common thing because I just replaced my iPhone 5 battery this morning and I am having the same problem.... I've never heard of it before until I saw this... And the only reason I saw this was because I have a problem. Has anyone found a solution yet? It is really frustrating!
Jordan tarafından
Yea and how do you make the toggle mute button wake the iphone?? I can't find out how?
Jordan tarafından
If it's not waking your iPhone when you flip the mute button, you need to turn OFF the "Vibrate on Silent" option. When that option is on, it just vibrates instead of turning on the screen.
asdas tarafından
Same problem. After replacing battery, home button doesn't work. :(
Mstar tarafından
4 tane daha yorum göster
